Samsung galaxy s20fe sim issue
PussyGalore
keeps saying no sim inserted, keep having to remove it and put it
@PussyGalore  Try taking the sim out and very carefully blow in to the sim slot you might have dust build up in there.  You could try putting a vacuum cleaner nozzle against the sim slot this might be the better option.   If the issues is still present after this you might need to request a replacement SIM card.
