08-05-2022 02:34 PM
I've had the s21 fe just over a month but I'm having to charge it a couple of times a day. More then my old phone that was 2 years old. I'm not doing anything out the ordinary on it ....play some games watch a few videos but also not doing anything different to what I was on my A71
08-05-2022 03:12 PM
@Kazjaz50 - You could install a battery monitoring app to see what is what.
https://play.google.com/store/apps/details?id=com.digibites.accubattery&hl=en_GB&gl=US
I've found the pro version of the app very useful for my device.
08-05-2022 04:57 PM
I've installed it but not sure what I'm looking for ......doesn't using a app drain the battery
08-05-2022 06:01 PM - edited 08-05-2022 06:02 PM
Hi @Kazjaz50
At what % are you charging?
You don't need a battery app as you already have one under settings - battery and device care. This will tell you what is draining your battery.
08-05-2022 06:07 PM
08-05-2022 06:14 PM
Hi @Kazjaz50
When it's low? What does that mean 10% or less?
It sounds like you are overreacting with your charging regime and don't need to charge your device. Go into the battery settings and activate %. You should get 24 hours+ depending on usage but if you are playing games then expect some decline in your battery.
Android is very good at managing battery power and will adapt to your usage.
08-05-2022 06:29 PM
I usually recharge probably about 30%
08-05-2022 06:51 PM
Hi @Kazjaz50
30% you have half a day + left on normal usage.
08-05-2022 07:09 PM
09-05-2022 05:54 AM
It looks like I'm the only one that has a problem with the battery draining so quickly so I'll to a shop and see what they say
