02-05-2022 07:22 PM
After an update my samsung s20 will not connect to my home WiFi. The hone WiFi is not an issue. Every other device is working perfectly. Even after a re set on WiFi and mobile my phone will not connect. Phone will connect to WiFi everywhere else. But not at home.
02-05-2022 07:47 PM
What happens when you try to connect to your home router?
Can the device see the hotspot network? Can you enter the password?
03-05-2022 06:32 AM
If it connects everywhere else except home then the issue is not your device. Have you maxed out your WiFi connection at home? Are you entering the correct password? Have you blocked the device in your home network by mistake?
