07-04-2024 03:13 PM
My tablet recently installed a system update now it starts up and enters Lock Screen as normal however when PIN is entered the tablet does not unlock and the screen goes to sleep. I’ve tried rebooting via the power button numerous times and also from the recovery screen but nothing works.
07-04-2024 03:55 PM
Apologies, should have explored further before posting original message however I’m sure I won’t be the only one with this issue. The newly installed system had randomly changed to login process. Before, entering the PIN directly started the boot up, but now a new button has appeared in the number pad - a ‘go’ arrow bottom-right which has to be pressed to start the boot up. Seems obvious now that I figured it out. Some on-screen prompts about this would have been helpful.
07-04-2024 03:55 PM
