22-03-2022 01:24 PM
I have a dodgy qr app on my phone and it won't allow me to remove it the usual ways. Any ideas please.
22-03-2022 02:11 PM
Try using PlayStore to remove it rather that the Phone.
Press and hold the App Icon, it should display 'App Info' or '!', go to Info, scroll down the List to Advanced, go to Advanced then scroll down to Store, App Installed from PlayStore, press it should open the PlayStore location with an UnInstall Button on the Top.
22-03-2022 01:51 PM
Which Phone model.
22-03-2022 01:53 PM
Samsung z flip 3
22-03-2022 01:57 PM
Is it a PlayStore App or Preinstalled Samsung App or from somewhere else
22-03-2022 02:03 PM
Playstore
22-03-2022 02:06 PM
I have tried using the TotalAV software that detected it but when you press to remove my phone just turns itself off and won't remove it.
The TotalAV software called it. com.dmpsq.srthp
22-03-2022 02:11 PM
22-03-2022 03:04 PM
It worked. Went into play store and removed it that way. Thank you so much.
22-03-2022 03:13 PM
Your welcome, glad it worked for you.
Chris.
