20-01-2023 10:15 AM
I moved to EE from BT in Dec.
Since then I am unable to use mobile data as I am to my S8 is not compatable with EE
I tried a another sim from 02
Which worked fine with data and phone.
This is very frustrating as Samsung say there is no issue
20-01-2023 12:15 PM
Hi @Fluff5
Welcome to the community.
Are you on contract or pay as you go? Do you have an active data allowance on that SIM card?
20-01-2023 12:18 PM
20-01-2023 12:33 PM
When you say your S8 is not compatible, what do you mean? Where was it purchased from?
You've not mentioned any problems making or receiving calls, so I presume that your phone is connecting to EE's network.
And if so, then problems with mobile data could just be a config issue - especially if the phone was previously used on a different network.
20-01-2023 12:44 PM
20-01-2023 01:15 PM
