06-12-2023 10:58 AM
Will my Samsung A04s be compatible with the 5g when 3g is turned off
06-12-2023 12:25 PM
@Kimmy12 : No, it's 4G which will work when 3G is switched off.
06-12-2023 12:28 PM
4G coverage often exceeds that of 3G already.
A 4G phone should very rarely, if ever, see 3G coverage now. On the rare occasion this happens, post sunset you will see 2G instead.
06-12-2023 03:55 PM
Thank you for the reply
06-12-2023 05:13 PM
06-12-2023 07:00 PM
That device doesn’t support 5G is only a 2,3,4G device. The 3G switch off can not make a device 5G compatible as that’s a hardware limitation of the device.
