11-03-2024 11:55 PM
Hello I am in Italy normally my allowance is unlimited for internet usebut my phone is not allowing me
12-03-2024 12:06 AM
@mg1962 : EE don't provide you with WiFi neither here nor abroad, unless you bought Broadband from them. So now we'll talk about use of mobile networks while roaming.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
