prepaid data sim card for motorhome
johnr2875
Hi. Bought this EE data card for my motorhome for on the go internet to be used in the router in the van. 120GB for £50 (12 months max) I have used this previously and could view the usage on my account. EE have now changed the website and doesnt matter what I do I cant use the website to monitor usage , after many phone calls to EE I am seem to be going around in circles !! A sim card has a mobile number but you dont use the mobile number for calls its only for data via a fixed router !!
BrianC3
If it is like mine it has a sms allowance - 100 txts I think. If you can put it in a phone and txt balance to 150 it might work. I had to do that with mine.
Hi. See my original topic message ..its a data only pre-paid sim card for using data on the internet.  120GB allowance. All I want to do is view the usage and unfortunately I cant gain access to an EE account to do this unlike I could with my last sim card and the previous EE website !!
@johnr2875 : Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
@BrianC3 : The SIM might very well have a SMS allowance but not all mobile routers can send SMS, altho' they can usually send them.
