03-08-2022 03:41 PM
Hi All
I'm looking for the T&C for the Unlimited Data pass.
Is it really unlimited, unrestricted ?
Cheers
03-08-2022 04:39 PM
Hi @DWW
Thanks for coming here.
All of our unlimited plans are uncapped so you can use as much data as you like, as long as it's for personal use. For more information on personal use, please see our terms and conditions.
You can find more details on our Unlimited Plans, Help page 🙂
Thanks 🙂
03-08-2022 04:39 PM
Hi @DWW
Thanks 🙂
03-08-2022 05:07 PM
Then why, @Leanne_T , does your latter link contradict your former link,
UNLIMITED PLANS
50GB fair usage policy applies outside UK. Personal, non-commercial use only.
03-08-2022 05:52 PM - edited 03-08-2022 05:59 PM
Hi @XRaySpeX
Sorry, I'm not sure I quite understand the question, both pages refer to the fair use policy when roaming as 50GB.
Which part is incorrect?
Thanks 🙂
03-08-2022 06:42 PM
@Leanne_T : Sorry, I'm getting mixed up between UK & roaming use but I would like to add to your response in answer to the OP's Q "Is it really unlimited, unrestricted " by drawing his attention to the relevant important restrictive condition that:
We will consider usage above 600GB/month to be non-personal use and have the right to apply traffic management controls to deprioritise your mobile traffic during busy periods or to move you to a business plan.
covered in both links.
03-08-2022 06:54 PM
03-08-2022 07:24 PM - edited 03-08-2022 07:25 PM
No its Unlimited Data but not Unristricted, you will be severely Speed Capped once you go past 599GB per month, or if you Gift Data from your UL Plan then the amount that you have Gifted plus your own Usage up to 600GB per month then again the Speed Cap kicks in.
