14-08-2022 04:21 PM
I am in Portugal and have had 4g for the first 4 days but today I haven’t been able to use mobile data at all, I do have signal, anyone know the issue?
14-08-2022 04:47 PM
Hello @Mbishop2704 ,
Welcome to the community,
Are you on pay as you go or contract? We would not know what the issues are as such, as you are not in the UK, that would be down to the network in Portugal. If on pay as you go, have you made sure you have enough credit, on contract have you checked roaming, call abroad and premium calls are enabled? Although that should not be the issue, as you have been able to use your data. Could you do a manual check to see if there is another network, where it might work?
14-08-2022 05:03 PM
14-08-2022 05:07 PM
@Mbishop2704 , when did you get your contract? Was it before the 7 July 2021 or after? If it was after, then you would have to make sure that you pay for roam further. I would suggest taking a look here:
