21-08-2023 12:25 PM
My Redmi Note 10 Pro phone will only connect to the internet via WIFI. I have just bought a mobile data add on which I cannot work out how to use. I have tried all the fixes suggested on the internet apart from a factory reset.
21-08-2023 12:44 PM
I take it you're on PAYG then... if calls work, try ring 150 and speak to someone
21-08-2023 12:44 PM
23-08-2023 06:58 AM
Thank you....apparently I was on a 3G plan and as 3G is being phased out I now need a 4G Sim to receive mobile data. EE are posting me one free.
