31-01-2023 02:26 PM
I am travelling to St Petersburg, Russia through Istanbul, Turkey. What is the best way to avoid roaming?
31-01-2023 05:43 PM
Enabling flight mode is the most reliable way of avoiding roaming - which is just the name for using your phone on a foreign network. If flight mode is on, then your phone cannot connect to foreign networks and will not incur charges for any resulting usage. Be aware of WiFi-calling which is not officially supported abroad but can sometimes work.
You could also contact EE C/S to remove the roaming functionality - this will prevent your phone connecting to foreign networks.
Disabling data roaming as previously suggested, will only stop your phone from using data on a foreign network - it won't prevent voice calls being made or received, should it be connected to a foreign network.
31-01-2023 02:38 PM
Switch off data roaming on your phone.
31-01-2023 02:54 PM
You might also want to turn off your voicemail. If you receive a call and answer it, you'll be charged.
31-01-2023 02:57 PM
But I might need to use my phone or laptop. Do I need a particular plan with EE and pay for that? I am travelling in a week.
31-01-2023 03:16 PM
Could u also specify how I can cancel voicemail? Sorry, I am a dummy, not quite technically experienced. Thank you
31-01-2023 03:53 PM
Hi @LucyL10
Thanks for coming here.
If you text VM OFF to 150 this will remove the voicemail for you.
For Roaming add-ons and costs if you would like to use the phone when roaming please see our Roaming Costs, Help page.
Before you go please text ROAMING to 150, to make sure your account is set up for roaming.
31-01-2023 05:01 PM
If you use your phone abroad you will be roaming, so you don't want to switch it off.
31-01-2023 05:43 PM
01-02-2023 01:14 PM
Many thanks, Leanne! So useful and helpful! Thank you for the links as well. Informative and easy to use. I am intending to follow your advice.
01-02-2023 01:20 PM
Many thanks!!!
