26-05-2022 03:46 PM
Could someone please clarify how much data can be gifted from a 160Gb sim plan.
Is it a percentage or a maximum amount?
26-05-2022 07:46 PM - edited 26-05-2022 07:47 PM
You can gift pretty much all of it or what's left of what you havent used, except you have to leave at least 500mb or up to 999mb if it doesn't roundup to 500mb when what ever is leftover.
26-05-2022 04:06 PM
@Miggs207 : There is no limit.
26-05-2022 04:21 PM
Thank you for your prompt reply.
So I can actually gift more from a 160 or 200Gb sim than I could from an unlimited one?
26-05-2022 04:31 PM
Apparently!
26-05-2022 10:02 PM - edited 26-05-2022 10:03 PM
@EssexBoyEE : I presume the system does not let you gift from the last 500 - 999 MB even if you try.
26-05-2022 10:38 PM - edited 26-05-2022 10:45 PM
@XRaySpeX yes Correct.
Just read my post again, wasn't very clear was it, but yes, if you've got 1001mb left then the max you can gift is 500mb anything less than 999mb then no because the system wants you to keep a min of 500mb as the gifting is done in 500mb slots.
