21-07-2023 08:22 PM
Hi
Just had a message saying my mobile data usage is 80%..which is ridiculous since I am on home WiFi most of the time plus with rollover is was more than my monthly allowance.
So will be complaining since something not right at their side.
Regards
Jas
21-07-2023 08:53 PM
Hi @JasBassra
Check the mobile data section in your phone’s settings, it should show your usage and what has been using the most data - maybe something has been using your data in the background?
Thanks,
Alex
21-07-2023 10:03 PM
@JasBassra : Are you on an unlimited data plan?
OR are you on PAYG?
