03-04-2024 07:03 PM
Hello,
I have a plan which turned out to have 1 major issue. Found out there's a 100GB cap on sharing your data. I've been using it for another one of my devices and once this limit is reached, the speeds plummet to 2 MB at BEST on my other device. This is insanity. I have 408£ to pay in order to terminate this nonsense. And the plan itself is comparable to O2 and 3 prices, but they don't have this unnoticeable yet highly important caveat. EE's new "call" service is also broken, so my only way to warn people is on here...
Regards,
Ves
03-04-2024 07:44 PM
@Veselintp What limit has been reached?
The gifting cap has been there since EE first started unlimited tariffs and gifting data.
How’s EE call service broken? I’ve spoken with customer services with no issues I just don’t select option 1 when I call customer services. Option 2.
03-04-2024 07:47 PM
It's not an issue! It's a design feature fully covered in the spec of Unlimited Data plans.
03-04-2024 08:46 PM - edited 03-04-2024 08:46 PM
A 100GB gifting limit or something of the sort. The speed is horrendous either way, but once the threshold is above 100GB, it is even sadder. Unbelievable. My plan is unlimited, but not so much, apparently. It is HIGHLY limited. They should include this in the plan, in bold letters.
Both options give me an error.
03-04-2024 08:48 PM
It's an issue because in the Unlimited Data plan selection, it doesn't say that Unlimited is actually "Reduced significantly after 100GB data share." It is incomprehensible.
03-04-2024 09:13 PM
Your speed isn't reduced on an Unlimited Data plan once you've gifted your full quota of 100 GB but only after you've used up your full FUP of 600 GB that month.
But in your OP whose speed was being reduced, you as the "unlimited" giver of the gift or the "limited" recipient of the gift ("on my other device")? If the latter, it has nowt to do with your Unlimited Data plan, but it is the other devices limited plan running out of data & being switched to slow Stay Connected Data.
03-04-2024 09:26 PM
I receive a text message every time I approach the 100GB gifting allowance. My other device is a PC that uses a wireless connection to my phone, it is not limited itself, it's the mobile plan for sure.
