07-05-2024 02:20 PM
Hi there, I am in Germany and tried to use google maps earlier and to my surprise and extreme inconvenience found the mobile data DID NOT WORK. I am paying for 100GB data per month including European roaming and find this inexplicable. Can you pls help troubleshoot the issue? I rarely use it when in Europe but today i did want to use and needed it to work and it did not work. Big fail, unacceptable and probably a breach of contract, too. Can someone advise? Thanks v much. Trevor
07-05-2024 02:24 PM
@Wilki : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
07-05-2024 03:03 PM
Thanks for replying. I have a contract (though am currently out of contract) which includes 100 GB data inc Europe. I was using it in UK before, but did not activate / text "roaming" - it normally does this automatically (at least in the past) when in a EU country. How do i activate roaming whilst here (in Germany)? Thanks again for the response.
07-05-2024 03:19 PM - edited 07-05-2024 03:20 PM
You mention having used your phone in the EU previously, when did you last receive a welcome text message in a foreign country? This is a good indication of having a local network connection.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
07-05-2024 04:11 PM
As I previously suggested you may call CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
