23-07-2023 11:58 AM
I need to increase my spend cap but can’t find how to do this in the website
23-07-2023 12:17 PM
@Olivex : Text CHANGE SPEND CAP to 150 and it will guide you through changing it. Changing your spend cap takes effect from the next bill cycle. Pausing it should change almost straight away.
23-07-2023 12:10 PM
Hello @Olivex ,
I have just checked, cannot find it on the app, if you cannot find it in settings, whether via the app or website when logged into your account, I would suggest ringing customer service and they should be able to do this for you.
23-07-2023 12:17 PM
