03-12-2022 05:02 PM
I'm eligible for an upgrade, but I want to downgrade.
There's no chat or phone number to contact EE, and I'm unsure how to do it.
I can choose a SIM-only plan, but I'm scared it will add an extra SIM to my current monthly contract. Is it best to cancel my contract? And then buy a SIM only from EE or a competitor?
03-12-2022 05:27 PM
Providing you follow the "upgrade" options on your myEE and choose a SIM-only plan you should be fine.
If you're at all unsure, simply call CS on 150 from your mobile and ask the agent to change your priceplan to whatever SIM-only plan you want. Perhaps don't use the term "upgrade" if doing it this way, but "change to SIM-only"
If you do this change by phone, the change of plan will usually be effectively immediately.
03-12-2022 05:27 PM
13-10-2023 10:14 PM
The upgrades team will do it for you. Just advise them you want to migrate from your current plan to sim only (avoiding upgrade/downgrade term to make it easy). If out of contract it changes immediately, if in a contract will take effect when your current plan ends
14-10-2023 02:33 AM
But, @ste2830 , will OP still need it nearly a year later?
