15-02-2024 06:29 PM
We have moved from BT to EE. I know they are now the same but do I continue to use my BT wi-fi login or should I have a new EE one
15-02-2024 07:29 PM
@MrsD53 For your WIFI password, if you have been given a new router then you should use the details from the new router.
However it seems some people do not get a new router, if you are one, then just carry on using the details from the router you are using.
If you mean something else, do let us know.
15-02-2024 07:11 PM
Do you mean the router's BB PPPoE Username & pwd? If so, they are the same as BT's.
15-02-2024 07:29 PM
15-02-2024 07:44 PM
Told we are keeping original router so question answered. Thanks
15-02-2024 07:46 PM
Thanks @MrsD53 glad we could help.
