Website says I have no products
EranB
I'm having connection issues. This happens periodically. A technician is Sent, fixes something outside and it's sorted for a while. It just happened again. This means my Nest camera is offline and I have no doorbell. I tried checking the service status, but the website tells me I have no product although I clearly do. What are my options?
Did you add your BB product to your MyEE? It doesn't just appear.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
Thanks for the prompt response, @XRaySpeX .
The thing is my broadband IS showing in MyEE. It only says I don't have it when I try to run a test. Seems like a website bug.
To get everything working I had to reboot the router, so I'll come back here when it drops again.
However, even then, running a wired speedtest in 2023 (almost 2024!) is quite an ask. What device would I have that has an ethernet socket? I'd have to buy an adapter solely for the sake of the test.
What test you trying to run on the EE website? Give its URL.
If you can't easily run a wired speedtest then just run it wireless.
I'm trying to run this one: Service status in your area (ee.co.uk)
But it immediately says "You don’t have any EE products".
Right now the wireless tests looks good. 29ms latency, 68.1 Mbps with bursts of 69.8 download, and 14.2 Mbps with 15.6 upload.
That link is for mobile service status only.
Please post the result link of the speedtest.
