09-02-2023 07:22 PM
I have set my 2.4 GHz WiFi to channel 6. Does anyone know why my router is also displaying 2 hidden ssid's on the 2.4 GHz band alongside the one set to channel 6, that I named as 2.4ghz.
Have factory reset router. Always done this and has been the same on each of the firmware updates that EE released.
I have spoken to EE, but they don't know what to say or do.
TIA
09-02-2023 08:34 PM - edited 09-02-2023 08:39 PM
@huggons in what way are they affecting your heater controls?
Have you tried the other channels? Or moved the router/heater control or even a bit of tin foil in between them?
PS, to be sure it is just the router, you would need to switch off your other Wi-Fi devices - printers for example also transmit on the same channel as the router, although do also have their own SSID.
09-02-2023 07:47 PM
Those hidden SSID's could be close mobile phones which are NOT connected to your SSID. They could also be smart meter connections, again NOT connected to you. They are nothing to worry about.
09-02-2023 08:03 PM
A quick way to check if the are associated with your router is to switch iy off. If the are still there it is another device transmitting them. If one or both go it could be part of a possible firmware upgrade - it is common until recently on the PN Hub 2, and I beleive the BT Smart Hub 2 uses it as part of the smart WIFI disc/mesh.
Still nothing to worry about though.
09-02-2023 08:18 PM - edited 09-02-2023 08:50 PM
Please post the form of these 3 SSIDs involved obscuring any personal names & all the digits. Do they contain 'EE'?
What shows on the Home > Advanced Settings > Advanced Wireless page, again obscuring any personal names & all the digits?
09-02-2023 08:20 PM
Thanks both.
They are coming from the router, disappear when I switch it off and reappear once power fully up again.
Need to get to the bottom of it, as our underfloor heating controls are being affected by the signal.
09-02-2023 08:43 PM
Hidden ssid's interfering with the channel wireless controls run on, according to Heatmiser, the manufacturer. Channel 6 is set for this purpose, but the hidden uds can move around the channels.
Hidden ssid's definitely coming from th EE router. Have you got one yourself?
Added screenshot
09-02-2023 09:02 PM
I am happy to say I don't have one, I prefer to use my own. Which may be a way forward for you.
I will tag in @bobpullen who may have some info regarding any updates due on the EE router.
09-02-2023 09:07 PM
Thanks. Interesting thread here https://community.bt.com/t5/Archive-Staging/Smart-Hub-2-Firmware-glitch-and-sneaky-networks/m-p/2004...
Seems to be the same issue. Looks like was "resolved" by a firmware update, however seems to be that this was only to address the issue of the hidden ssid's still showing when WiFi was disabled. I would suggest that you should also be able to stop these additional hidden ssid's being broadcast alongside the SSID that you actually want. Shame EE tech support are not able to understand the issue
09-02-2023 10:34 PM
