20-02-2023 08:23 PM
Hello everyone, first post ! Not surely the forum format, but I’ll have a go!
As per the title, “My Broadband has more than halved in speed”, (from 74 Mb/s to 32 Mb/s download)
So then, I upgraded from my “non-fibre” plan (which was about 12 Mb/s down, and 1 Mb/s up) to the “fibre plus package”: 74 Mb/s down/18 Mb/s up, and everything was fine for nearly 2 years and was very satisfactory.
However, since about the end of December 2022 my download speeds have dropped to 32 (Mb/s) with an upload of 13 Mb/s. These speeds may seem sufficient for most people (a single 4K is fine with this speed), but as a multi-user, it falls short of what I need- but on what I HAD — 74Mb/s.
I’ve not contacted EE just yet (save a few texts for refreshes etc), but I’ve done a few tests/changes etc, myself. I’ve also experimented with different channels, and even done a full factory reset - all to no avail, still the same speeds.
Now I understand that 34 Mb/s minimum speeds are guaranteed on Fibre-plus (which I am on) and comes pretty close to the 32 Mb/s I get. But now, however, with about a 60% drop in speed, I’m concerned that I’m paying for something I don’t have (£36.54 Per-month). The non-fibre plus is roughly what I feel I’m paying for (36 Mb/s estimated/18 Mb/s minimum) - even though I’m above that minimum.
So with all the above said, can anyone point me as to what’s happened? Nothing has been touched around the phone area (I have no phone) same filter, though I’ve tried others.
posted an image below if that helps (it says 35/15 (down/up) but don’t get that on Speed-test/youtube/Netflix etc., but more like 31 Mb/s
https://broadband.ee.co.uk/select-your-speed
Thank you.
Anthony.
22-02-2023 10:36 PM
Thanks XraySpeX
The engineer came very early this morning (though a afternoon visit was booked)!
He was here about 90 mins, and he put me a new telephone socket in the lounge to replace the old one (that was much appreciated ). And after a few tests, he got it up no running to the speeds I had last time (almost) 71Mb/s down/18.5 Mb/s up.
As my modem was reset,new wires, location and soon, was told it will take a while to settle down.
Thanks.
Anthony.
20-02-2023 09:42 PM
20-02-2023 10:20 PM - edited 20-02-2023 10:32 PM
20-02-2023 10:23 PM - edited 20-02-2023 10:27 PM
Thanks XraySpeX
Posted a screen-shot above. Unfortunately I Don’t have access to a Ethernet cable/wired test, as only my my LG-TV/iPad/mobile devices are available.
Regards..
20-02-2023 10:24 PM
@Antx777 the chances the automated DLM has reduced your speeds due to noise or breaks on your line. If you dial 17070 option 2 is the line quiet = if not repost a phone fault.
Sight of the info requested above will help, however it seems an engineer is needed to resolve your problem, so the sooner a fault is reported the sooner it will get fixed.
https://ee.co.uk/contact-ee/technical-support/broadband-landline
20-02-2023 11:33 PM - edited 20-02-2023 11:36 PM
Thanks for the reply Mustrum.
I Don’t actually have a landline phone anymore, so I can’t perform the Dial-option you mentioned in your post. However, I’m now texting HELP to 60071 (Via Text Message) I think I did this before, with conflicting messages.
I’m now waiting for a response and will post tomorrow when I hear from them/It.
Regards
Anthony
21-02-2023 12:08 AM
@Antx777 an old fashioned phone is one of the best tools to work out phone line based broadband problems. But good that you have fault reported, please do let us know how it goes, it will hopefully help others in the future.
21-02-2023 01:28 AM
2. Can you then do the speedtest over WiFi?
3. I'm still waiting for the BTw Availability Checker estimates.
If your BB comes with landline voice services but you are just not using them, are you able to get hold of a cheap handset so we can check for noise on the line?
21-02-2023 10:39 AM
Good morning
Yes, I can do speedtest over wi-fi, and my connection is fine- just SLOWER!
I text them this morning and got this: “Hi, it's the EE Diagnostics bot here.
We have found a fault and we need to send an engineer to restore your service.
Sometimes engineers need to access your property on the day, so please make sure someone is home during your appointment time.
Reply just the word "NEXT" to book the next available slot in your area””
So it looks like I’ll be having an engineer coming Thursday/Friday.. I may have an older headset somewhere, but I’ll leave it to the engineers I think.
Thanks.
Anthony.
21-02-2023 11:36 AM
An Update.
I spoke to one of the Advisors this morning (11.15 am) , and they have arranged to have an engineer to come and see me tomorrow afternoon, 1pm -6 pm. A very helpful staff member talked me through the process of my problem (with the line). Also, he was able to get my speeds back up to 72 Mb/s/18.5 Mb/s (download/upload) temporarily from his end, but he said that the fault on the line may slow it down again, so an engineer is required.
Thanks, and I’ll keep you updated tomorrow on the progress made.
Anthony
