22-02-2024 09:28 PM
My broadband speed has also more or less halved - getting 20-24Mbps when it should be at least double that.
Just seems to have happened tonight, but if it's the ame tomorrow I'll be calling EE,
Braid band was only put in just over a month ago, so not happy at all at this,
Add to that the £50 EE voucher that I can only spend on selected products and not one that I acctually want and the 14.4% rise in mobile and braodband bills - I'll be saying goodbaye to EE when each of my contracts ends - a real masterclass in how to lose customers, well done EE!
22-02-2024 09:34 PM
@Mikey-Mike : Welcome to EE's Home Broadband Forum.
EE's annual increase this year 7.9%. 14.4% was last year!
