22-08-2023 08:57 PM
According to 192.168.1.254 i have both bands turned on. I am unable to name them separately and no device can see the two bands. Just one entry for my HBB.
22-08-2023 09:16 PM
@MattCook They are both the same network it’s just two different frequencies that devices can use to connect to your router. Your devices choose what band to connect to. 2.4Ghz is better for long distance but 5Ghz is faster but only for shorter distances. Your devices choose what’s best at that time.
22-08-2023 09:31 PM
@MattCook I presume you have the new white Smart Router - which does not allow you to split the bands.
Most modern devices cope and automatically swap bands if they move out of range.
If you are having trouble connecting a 2.4Ghz device, then if you temporarily switch off the 5Ghz band off it will normally connect ok, and stay connected when you switch the 5Ghz back on.
22-08-2023 09:59 PM
Which router do you have? With the white EE Smart Router, unlike the black EE Smart Hub, you cannot separate the wireless bands/SSIDs. The most you can do is on the Advanced > Wireless Settings page to temporarily disable the 5 GHz band & move off the Smart channel while connecting problematic 2.4 GHz devices.
22-08-2023 10:06 PM
Damn thats what ill have to do then.
I ah e several smsrt plugs and bulbs but their set ups require the 2.5 band.
My old ee router would let me have both and showed both for me to choose.
I wonder of there's a reason for this backward step.
22-08-2023 10:22 PM
@MattCook what is your old router, and why do you have a new one? If the old router is still working and you have not changed service the simplest solution would be to revert to the old router.
22-08-2023 10:56 PM
Which EE BB product do you have? Is it "Fibre Max" something?
@Mustrum : Chances are that if OP has been given the white Smart Router then he's on G.Fast BB which no previous EE router would handle.
22-08-2023 11:15 PM
I have a new one cause EE told me had to have a new one and send the old one back.
23-08-2023 07:05 AM
@MattCook As yet I’ve never had to temporarily switch off 5Ghz so a 2.4Ghz device can be connected up without issue. I’ve more than one occasion reset my router so had to reconnect all my devices and still never had an issue.
