11-03-2024 01:42 AM
I’ve had EE Full works kit 6 days, install was complete faff, the most convoluted installation process I’ve ever had.
speeds great I get 800Mbps, everything connects great until you want to game. CoD mw3 I have to try and connect 8 times to the servers before actually being able to game.
tested various settings, port forwarding still the same out come disconnected from server, when I do get on the split second lag spikes every other minuet are horrendous making the game unplayable.
tonight I plugged in my old BT HUB to test a theroy and it connected to the games servers instantly, I tested this several times over an hour with out fault and the game ran smoothly
what’s wrong with your hardware EE I believe you’ve got it hidden behind a pay wall hence the GAME MODE offer.
cancelling the contract tomorrow and going back to my BT HUB
11-03-2024 10:24 AM
Hi @M1GHTYB34R I'm really sorry about the problems you're experiencing, I think it would be good to get our Hub team to look at this.
I'll send you a private message so you can get in touch with your details.
Neil
14-03-2024 06:33 PM
If you have the hub plus try using the geo filtering i have the actual modem Netduma and its come ting me only to the uk servers low pong .
