EE Smart Router Manager remove devices
botty_1963
When I look at the wireless I have quite a number of unknown devices showing green, so connected and therefore I cannot remove them. Is there any way of removing them as I have no idea whether they are genuine connections or not, and I don't really want to have to change the password as I will have lots of known devices to reconnect.
I have also noticed that my Pixel 6 phone is showing there as four connections, but I have had it powered off for the last hour to test.
24 REPLIES 24
You may only remove disconnected greyed-out devices.
Can't you tell what they are by looking up their MACs?
Why would changing your pwd help you?
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
But how do we remove the grey ones? I have lots of ones I want to delete like old phones, old devices but cannot figure out how to do it in the EE home app for the router
@Loopylass : You do it on the router itself.
Ahhh okay thanks, I’m not fantastic at that sort of stuff, would you be able to give a little instructions on how to do it from the router itself? Thanks in advance
@Loopylass : Go to Advanced Settings > My Network > My Devices & Remove any grey device you want.
Wavydavy
I have exactly this problem but can’t figure out how to remove unwanted connections. Please can someone help I am losing the will to live!
@Wavydavy : Just read the answer I gave just above your post.
I don’t have advanced setting on the EE app for the router box.
@Loopylass : No, not the app! Login to the router itself.
