04-12-2023 01:19 PM
I took out an EE/BT broadband contract and received a Smart Hub SH31B. I logged into the router and tried to put it into modem or stelth mode so I can connect it to my mesh network. This was unsuccessful due to the settings heavily restricted by EE/BT. I called the technical team asking for this to be applied to my Smart Hub and was told this is not possible. I changed the settings on my Virgin router to modem without any difficulty. I also did it with many other router brands, Netgear, TP-Link, Asus, Linksys, etc. How is this not possible with the EE/BT router? I know it can be done! Unfortunately I had to cancel my contract within the 14 days period and go back to Virgin. EE/BT please sort your life out.
04-12-2023 01:24 PM - edited 04-12-2023 01:26 PM
You can't put a EE SH+ router into modem only mode. The facility just ain't there regardless of what you can do with other routers. However you don't need to just to add a mesh. You could disable the WiFi on it & let the mesh handle all WiFi connections if you like.
04-12-2023 02:06 PM
04-12-2023 02:15 PM
Perhaps I didn't make myself clear. You don't need the SH+ to act as a modem only in order to just add a mesh.
There'll be no IP conflict. The mesh will have its own IP subnet.
04-12-2023 02:37 PM
04-12-2023 02:49 PM
What type of BB are you getting from EE? If it's Full Fibre (FTTP) you don't even need to use the router. You can plug the mesh straight into the ONT. The ONT is the modem.
04-12-2023 02:50 PM
@HARVS980 are you on full fibre ?
If so the ONT is the modem, no need for the EE Hub, just connect your mesh to the ONT in PPOE mode and use the default BT username/passord bthomehub@btbroadband.com .
