18-12-2023 05:16 PM
Just switched over from BT to EE. With Bt you could import and export contact phone lists by logging on to the hub. EE only seems to have an import choice. Export is needed so that any changes you add to the phone numbers and contacts can be saved to a computer for future use. If that cannot be done all the data is lost if you have to reset the system. Or am I missing something.
23-01-2024 10:10 PM
Same thing has happend to my phone. Luckily I have my contacts on my mobile otherwise all would be lost. Can anyone from EE sort this problem out?
