Broadband keeps disconnecting
johnday
Yesterday problem started when I got up around 6 am tried turning off the router, went on for almost an hour
This morning exact same thing
6 REPLIES 6
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
daffu
Having same problems, have had 3 engineer visits now and still not resolved the issue! had the router replaced, new NTE socket rewired and a DLM Reset and still there is a fault on the line, and it just keeps dropping connection, im stuck in a loop of engineer visits that leave it working and then like an hour later the same issues again of losing connection flashing orange light. My upstream was going down, then my downstream went all the way down to 4.3Mbps when it should be on 20mbps. Becoming very frustrated with this now as I work from home, and nobody seems to know how to fix this. I'm going to request to be released from my contract and look for another provider.
Having same problems, have had 3 engineer visits now and still not resolved the issue! had the router replaced, new NTE socket installed and rewired and a DLM Reset and still there is a fault on the line, and it just keeps dropping connection, im stuck in a loop of engineer visits that leave it working and then like an hour later the same issues again of losing connection flashing orange light. My upstream was going down, then my downstream went all the way down to 4.3Mbps when it should be on 20mbps. Becoming very frustrated with this now as I work from home, and nobody seems to know how to fix this. I'm going to request to be released from my contract and look for another provider. All was working fine but this issue has now been going on for close to 3 weeks now and still not resolved.
@daffu : Well, how about providing the diagnostics asked of the OP above & maybe we can get a bit further forward than you've got so far?
Hi
Don't matter how many time you ring up to complain or how many engineers you have out it never get resolved, they keep coming up with excuses like i live to far away from the exchange or time of day.  Mine was going off any time of day or night,  I still think they flick a button & switch you off cos they can. so i changed suppliers in the end. I wasn't in contract with them so it was straight forward.  BEST THING I EVER DID.
Help123456
In having the same issue
