I phone 14 esim
Joshgbcafc
I’ve changed my SIM card to e sim for my new phone but then deleted by accident and I can’t get my SIM card to work on either phone what shall I do?
@Joshgbcafc  You need to request a replacement SIM card.    Your old sim will never work as you moved the information from it to the eSim.     Only use an eSim if you need to you don’t gain anything by using it if you don’t need to and you only cause issues like this.
