Calling not working
alexnemes98
Hi.
just got a new iPhone 14 pro but I can’t make any calls or receive calls. The data is working fine just won’t make calls. tried everything that I could find online but no luck. Can’t call EE neither
11 REPLIES 11
Katie_B
Hello @alexnemes98
Does your phone show was connect to the EE network?
Have you ported your number to EE?
Katie
Hi.
My number was already with EE.
Thanks.
Christopher_G
What happens when you try to make a call, @alexnemes98? Does the same thing happen when connected to, and not connected to WiFi?
Hi.
It will try to call then hang up straight away. It does it no matter if WiFi or data is activated. I’ve had my phone number for years with EE and now I just changed my phone and since I’ve put my old sim into the new phone this happens.
Christopher_G
Does it show an EE signal, @alexnemes98? Did you get a new SIM with the phone? If so, are you able to try that one?
Hi.
It shows full signal yes. I don’t have a new sim
Christopher_G
OK, thanks @alexnemes98
I think it's probably best to speak to our technical support team so they can check everything from our side.
I know but I can’t call them.
Christopher_G
There's a live chat service on that link I posts, and some contact numbers to call from another network, @alexnemes98
Hope you get sorted.
