29-09-2022 05:53 PM
Battery is draining fast and reception is one one bar and keeps dropping. Anyone else?
29-09-2022 06:49 PM
@Keithscott1_1 Have you just upgraded that device from an older iPhone ? If you have the device is doing a lot of indexing in the background of your information. The battery should be back to normal after 24-48 hours. Don’t forget as it’s a new device I’m sure you’re also messing about with it also.
30-09-2022 12:04 AM
Have you updated to iOS 6.0.2 yet? But as @Chris_B says, if you've transferred a lot of data (whether a direct phone-to-phone transfer, restoring from an iCloud backup, or just downloading data from iCloud) it will take a good day or two for the system to perform a variety of background tasks which will drain the battery a bit.
