Pixel 6A - battery drain after android 14 update
FillN
Hi
Last week my phone updated to Android 14 and ever since I am having real issues with battery drain and the phone getting hot.. I have tried many suggestions such as changing battery settings and checking the apps are all updated and not specifically draining, but nothing has helped. I have around 6 month before i can upgrade and do not want to have to deal with this for this length of time.
It looks like many users had the same issue, however more so back in November when the Beta came out. Any suggestions would be much appreciated.
@FillN  have you tried a factory reset?
Northerner
Hi @FillN
You'll need to contact Google about this issue as this is their software.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
No I don't want to reset the phone if I can avoid it, also don't see why I should have to after simply upgrading the OS. Cheers
OK, just wondered if anyone else had the same issue recently. Cheers
