20-03-2024 04:20 PM
I have a Samsung S23 with an EE SIM card. I use BT Broadband Hub 5.
I rely on wifi calling at home as the EE network signal is poor indoors.
Big problem is that the wifi calling feature keeps disconnecting and I have to reset or power off/on to get it back. Even then it disconnects without warning.
Any help appreciated.
20-03-2024 04:23 PM
What do you mean by "the wifi calling keeps disconnecting"? Do you mean calls are dropping when using the service? Or that the WiFi-calling symbol is disappearing but the underlying wireless connection remains?
Is your phone set to "mobile preferred" or "WiFi-preferred"?
20-03-2024 04:43 PM
To confirm that the Wifi calling symbol disappears although the broadband connection is still on.
Phone is constantly set to "Wifi preferred"
20-03-2024 04:59 PM
The next check would then be to ID whether the problem is device or router-related. Does the same thing happen on other broadband/wireless hotspots? And do other phones have the same issue with yours?
20-03-2024 05:30 PM
Not tried any other broadband/wireless connections as the issue is at home.
We also have a Samsung S21 at home which doesnt seem to have the same problem.
