19-03-2024 01:12 PM
can anyone help me, I am locked out my mobile phone as I changed pattern and Ive stupidly forgot patterrn, have no means to call EE and ask for help???on laptop,there is no live chat so I can't get into phone or contact EE for help??
19-03-2024 01:17 PM
@Eleanor-53 EE can not help you gain access to your device they don’t know the passcode. Your only option is a factory reset and if you don’t have a backup of the device you’ll loose all information on it.
19-03-2024 01:30 PM
Hello
What kind of phone do you have?
19-03-2024 01:37 PM
Samsung A54
19-03-2024 01:40 PM
If EE could just call me, I know they could go into my settings and remove pattern but Ive no way of contacting them
19-03-2024 02:00 PM
Do you know if you have Remote Unlock enabled on your Phone?
If you have a Samsung Account login to here - https://www.samsung.com/uk/apps/smartthings-find/
If you haven't enabled Remote Unlock then as @Chris_B said it will be case of Factory Resetting your Phone which means you'll loose everything unless you've backed your Phone up.
19-03-2024 02:14 PM
I will look now, however I cant do a factory reset as it wont allow my to switch phone off
19-03-2024 02:18 PM
If that isn't an option. Then to Factory Reset your phone log in with your Google Account by Going here - https://support.google.com/android/answer/6160491?hl=en-GB
It will give you a Guide.
19-03-2024 02:34 PM
Hi
19-03-2024 04:28 PM
Which link did you follow?
