WiFi calling
pokbhoy
Hi, I've just recently joined EE on SIM only, I was previously with Vodafone, I work offshore so only have WiFi but when I was with VF WiFi calling worked perfectly, I have the same phone but with EE WiFi calling doesn't work .. it's enabled in settings..
Any help would be great 👍
6 REPLIES 6
James_B
Hi @pokbhoy,
Where is the WiFi network based? Is it a maritime network?
EE WiFi Calling will only work if it can see you're in the UK.
Hi James ,
Thanks for your reply, it's not a maritime network.
I was wondering if I maybe need to speak to EE incase they need to enable it from their end.
Just strange how it worked fine with Vodafone.
James_B
Hi @pokbhoy,
WiFi Calling is enabled by default. If you are offshore, I suspect the network can't be identified as UK based and so it won't allow WiFi Calling to connect.
Legend
Legend
WiFi-calling is only officially supported in the UK.
It can sometimes work abroad, but calls made in this way will be charged as normal roaming calls - it's not a way to avoid call charges.
Cheers James ,
Sent from Outlook for Android<>
James_B
No problem @pokbhoy 🙂
