04-04-2024 09:24 AM
Since setting up my new 15 pro, I’ve had a very poor WiFi connection, which I never experienced on my 12. It’s so poor that it keeps trying to switch to 5G, which is very hit and miss in my house. I can find lots of comments about this in Apple communities, but suspiciously nothing at all from Apple or providers. In my experience, that usually means it’s a known problem without a fix. Anyone know of a solution?
04-04-2024 10:48 AM - edited 04-04-2024 10:50 AM
Hi @eb154
What router and wifi/ network are you using. It maybe an issue with your router as people just assume its the phone (not uncommon).
For example IOS used to have issues with the eero I use.
