08-04-2023 09:09 AM
Why do I get 'Not delivered' message when I text one of my contacts? This started a few days ago. I can text anyone else and I can receive texts from this contact but I can't reply.
08-04-2023 12:24 PM
08-04-2023 12:41 PM
Yes I am
08-04-2023 12:58 PM
Do you know if they're having problems receiving messages from other contacts, @KernowJac?
08-04-2023 01:11 PM
No they're not, it's just I can't text them
08-04-2023 03:07 PM
I'm unsure on whether this is a problem with you not being able to send a message to them or them being able to receive a message from you, @KernowJac.
I would recommend speaking with our technical support team so they can check everything from our side for you. Hopefully they can get to the bottom of the problem.
