20-10-2023 09:24 PM
Hello! I have a Samsung Galaxy Note 9. Recently I accidentally deleted the EE voicemail number, and since then, although I reinstated the number in my contacts, I have a notification message telling me I have a voicemail message waiting that I can't clear, even after restarting the phone.
When I click the notification, it says "USSD code running... ", and then after a few seconds, "Connection problem or invalid MMI code".
I've tried resetting the network settings, putting it in and out of flight mode, and removing and reinserting the SIM card, to no avail. Hoping someone else has a better plan! Many thanks.
21-10-2023 09:14 AM
Could you try texting VM OFF to 150, then once that has been processed, text VM ON to 150? Hopefully that resets the voicemail for you so that you can listen to that voicemail.
21-10-2023 10:56 AM
Try leaving a new voicemail, listening to it and either saving or deleting it.
