26-10-2022 01:47 PM
Hi
If I try to access Voicemail on the Pixel Watch LTE without the phone around it gets a "number out of service" response.
It works fine when connected via Bluetooth.
Is there a setting or do I need a call?
26-10-2022 04:08 PM
Hi @Timewarp,
Do you have an active data plan for your watch?
Do other features work away from your phone?
26-10-2022 04:35 PM
Hi @James_B
Yes, I have an active data plan.
Yes they do. If I dial 222 or use the Voicemail option on the watch app when the phone isn't connected, that's when it doesn't work.
26-10-2022 05:53 PM
Hi @Timewarp,
Please get in touch with our Technical Support Team so they can take a look at this for you.
They'll be happy to help. 🙂
26-10-2022 06:28 PM
@Timewarp When you say the phone isn’t connected are you testing this with the phone switched off or are you just turning Bluetooth off ?
26-10-2022 07:28 PM - edited 26-10-2022 07:29 PM
Phone in flight mode with Bluetooth off.
26-10-2022 07:52 PM - edited 26-10-2022 07:55 PM
Also tried with the phone off and got the same "I'm sorry the number you have dialled is no longer in service".
Call history shows "+447953222222“
27-10-2022 08:23 AM
I'd recommend following @James_B's advice and speak to our Technical Support team, @Timewarp.
Hopefully they'll be able to fix this for you.
27-10-2022 04:01 PM
I just rang and apparently everything is setup correctly on my account.
They put it down to a quirk of the new watch/system. Long story short, it's not possible to dial the voicemail number from the watch without the phone connected.
I'd be interested to hear if everyone on LTE Pixel/Galaxy watches has the same issue on EE.
28-10-2022 10:29 AM
Same for me.
