07-02-2024 12:52 PM
Am not able to make calls out from local hospital. EE help suggests turning WI-FI calling on but I do not have this option in setting/connections? Can anyone let me know if this can be corrected please
07-02-2024 03:51 PM - edited 07-02-2024 03:52 PM
The exact menu location may differ depending on Android versions, but should be under "Call settings". The following screenshot was taken from an Android 13 device, which is now running Android 14 and the option is very similar.
07-02-2024 03:13 PM
07-02-2024 03:20 PM
Hi Katie_B
Thank you, I have tried these steps but after opening the connection option I do not have WI-FI calling listed at all? Have you come across this by any chance?
Thank you,
Ian
07-02-2024 04:44 PM
Thank you, just you said in call settings.
Much appreciated,
Ian
