12-11-2023 09:40 PM
Hi I have a rattle inside my Galaxy S22 ultra 5G and it sometimes overheats
12-11-2023 10:20 PM
I'd recommend contacting your local EE store - https://ee.co.uk/local-repairs
Rattling is a sign of something physically wrong.
20-11-2023 01:03 PM
The rattle can be the optical image stabiliser in the camera lens, it's designed to move the lens to reduce camera shake.
Over heating may be an app or firmware, try the phone in safe mode or a factory reset. The repair centre will do a reset anyway so best try before you pay for someone else to try it.
