14-04-2021 09:13 AM
My understanding is that Dual SIM is supported on this device, but does anyone know if two nano SIMs can be used or is the second SIM an eSIM only?
14-04-2021 09:16 AM
Hi its 1x physical sim and 1x e sim 🙂
14-04-2021 09:22 AM
Thanks, assume they can be used at the same time rather than one or the other?
14-04-2021 11:33 AM - edited 14-04-2021 11:44 AM
Hi @afternoonboy. Welcome to the community.
I hope you're well and having a nice day, are you up to much?
@Tanyaoshea1 is spot on, for your first question.
An eSIM and physical SIM can be used in parallel on the same device.
You can find out more about this on our What is an eSIM Help page.
Thanks.
Chris.
14-04-2021 12:13 PM
Thanks @Tanyaoshea1 and @Christopher_B
One last question; is the Oppo Find X3 Pro supplied as network locked to EE or will I be able to use another networks SIM?
14-04-2021 01:36 PM
@afternoonboy Most devices sold by EE are 'locked' to EE. This means they won't work with another network's SIM card.
Once you've had the device six months you can request it be unlocked. You can find out more about this on our unlocking page. However OPPO devices are one of a few that don't come locked, so you should be able to use it with any network 😊
Thanks.
Chris.
22-07-2022 03:25 PM
It's either 2 physical sims or 1 physical and 1 e-sim
22-07-2022 04:07 PM
If its a proper Dual Sim, then it will have 2 x Sim Slots for Sim Cards, and if the thats the case and it supports eSim then it will also have 2 x eSim options.
So based on the above, it will have 4 x Sim Options but only any 2 of the options can be used at the same time in any order.
If the Phone came from EE after December 2021 then it should be Sim and Network Free, prior to that Date its probably Sim Locked
22-07-2022 04:12 PM
I have the phone (not from EE) and you are correct! It's does have two physical sim slots - I currently have one physical sim and one e-sim in operation, which is the basis for my previous post without properly checking! But looking at the settings again and there is an option to download a further e-sim. So yes 4 sims but only 2 at any one time in any combination
