20-09-2023 11:43 AM
I don't get signal anywhere in my house change to ee cause they said I will have it if I took SIM deal done the deal still no WiFi calling
20-09-2023 11:26 AM
20-09-2023 11:29 AM
I don't get a signal in my house I moved to EE SIM instead of BT cause they said it would have WiFi calling witch it doesn't
20-09-2023 11:41 AM
20-09-2023 11:49 AM
@Dondontrip1 which phone are you using?
Do you have landline or fibre broadband at home?
Is the phone connected to the broadband?
22-09-2023 12:19 PM
Am using an Xperia 10 11 I know I can get it cause I had it with 02 but I went to bt and couldn't get signal so moved to EE cause they said I will get WiFi calling but I don't
22-09-2023 12:27 PM
I have fibre broadband but don't get no signal unless I put phone at window and it never connects itself I have to do it every time I put at window if am outside works perfect
22-09-2023 12:28 PM
Hi @Dondontrip1,
Is WiFi Calling turned on in your phone's settings?
22-09-2023 02:11 PM
I can't find it anywhere but I have it cause I had it with 02
22-09-2023 02:14 PM
