28-11-2022 10:19 AM
Hello all
My phone (Samsung S20) is being swapped on the EE insurance. Apparently they pick the broken phone up and the same time.
How do I transfer the data - presumably the DPD guy wont want to wait?!?
Cheers
28-11-2022 10:33 AM
Hi @dickintexas
Can you backup your device on Google and wipe your device?
28-11-2022 12:59 PM
Thanks, I think I can - does that save all the settings etc. (not just pictures etc.)?
28-11-2022 01:17 PM
@dickintexas , should do, yes, if you use the back-up when install from the back-up, all your settings etc should be there.
28-11-2022 01:54 PM
Awesome, thanks for the help both
