14-02-2022 09:36 PM
Hi, my headphone jack has broken off and is stuck inside my galaxy a71. Is there any way to remove it?
14-02-2022 09:44 PM
There's quite a few guides online that give tips on removing the broken jack.
But this video shows how to do it quite well. Hope it helps you out.
14-02-2022 10:33 PM
I've tried the pen twice with no luck. I'll try the chewing gum now. Thank you 🙂
14-02-2022 10:35 PM
Your welcome, hope it works for you 🙂
