26-05-2022 11:58 PM
I've 'upgraded' from a Huawei P20 pro to a Google Pixel 6. After a few weeks I'm finding consistent connection issues, something I didn't experience in 2 years using the Huawei. What do you recommend? I've had the upgrade less than a month - so presumably there is an option to change it? Is this phone known to have problems?
27-05-2022 02:24 AM
You only have a statutory 14-day "change of mind" right of return when you ordered by phone or online. You have passed that.
27-05-2022 09:11 AM
27-05-2022 09:23 AM
Ohhh I'm at day 17 🫠
So a couple of examples - I'll be talking on the phone and suddenly the other person can't hear me properly - saying my voice is cutting out and sounding robotic. Even though I've not moved around and it was fine at the start of the call - and on my old phone I didn't have this issue in the same places. I've also found where I used to have signal using my Huawei I don't have any with a newer phone in the Google Pixel. Just doesn't seem right you know? Same network, newer phone with 5G and it's not performing very well.
Another thing I had with this phone was my storage was complaining of being too full when I transferred over - I deleted loads of pictures and emails because it kept saying it was at 90+ percent, even got a few times saying if it gets full I won't get any emails and it was at 98/99% full. I didn't really understand as I deleted gigabytes of data. Eventually I gave in to purchasing extra storage from Google - altho it felt like there was something not quite right as again I didn't have a problem with storage on my Huawei 🤷🏻♂️
Thanks! 🙂
27-05-2022 09:36 AM
Thanks for getting back to me @Tpaz.
Does your phone cutting out happen in more than one location?
Have you been able to check the Network Status Checker for any known issues?
What memory size does your new phone have compared to your old?
Katie 🙂
27-05-2022 10:22 AM
No problem 🙂
And I've noticed it both at home and at work - whereas my Huawei didn't have any issue at either location for signal strength.
The status checker says 5G is actually a lot worse than 4G or 3G.. but then I don't think it's often on 5G anyway.
Both have 8gb RAM.
Cheers!
27-05-2022 11:29 AM - edited 27-05-2022 11:29 AM
Thanks for checking @Tpaz67.
Do you find the service is better when using 4G?
Have you enabled WiFi Calling?
Katie.
02-10-2022 01:54 PM
This could of been written by me. Exact same thing happening to me. Keeps coming up with 4g and 5g but nothing loads up and also there is a ! Through the signal bar
02-10-2022 03:24 PM
Hi@Ramone123ASH
Does this happen in more than one location? Are there any known maintenance works in your area? You can check on our network status checker.
24-10-2022 07:08 PM
Exactly the same issues with my phone and my wife's phone, both Pixel 6 Pro, both get the !, 4G nothing loads, calls where either we can't be heard, or can't here. It's an absolute nightmare, and seems to be getting worse all the time....
