23-03-2021 12:35 PM
Anyone else having issues with apps today? I have checked for updates and there isn't any. Reset my phone and still nothing. You go to open it and it just closes. Any ideas? I have huawei p30 pro
23-03-2021 06:03 PM
Just found an easy fix on YouTube....go to settings, then Apps on your phone, and uninstall Android Web-viewer. My works okay now....phew!
23-03-2021 12:47 PM
Mines doing exactly the same. Doing it with emails, banking app, Google search widget, games. I've got a Samsung s21 only had it 2 weeks as well.
23-03-2021 02:27 PM
Hi @Sambond89 @Nd7
https://www.bbc.co.uk/news/technology-56496783
You should be able to download an update from the play store.
Thanks,
23-03-2021 04:37 PM
My phone is doing the same thing. I have been to Android System Web View via Google Play Store. I can find anything on it to allow me to down load the app? Advice please?
23-03-2021 04:44 PM
I'm have trouble with my s21 brand new my apps keep on crashing getting on my nerves
23-03-2021 04:51 PM
I have a similar issue. Gmail and google bomb out. Also, all of my game apps vanished amd will not reinstall
23-03-2021 04:57 PM
I am having the same problem. Started last night, went through device care, system check, uninstalled and reinstalled every app and clear cache... can anyone help? Kicking me out of absolutely everything!
23-03-2021 05:09 PM
looks like a lot of people are having the same problem
Mine was ok most of the day. about 8pm just stopped working and getting the same as you
Tried contacting EE but all shops are closed ATM
23-03-2021 05:17 PM
i am trying to download but my phone is not letting me do that either
23-03-2021 05:20 PM
there is a few people having same issue, check on another post there is some links
I'm trying to download something to help.....no luck yet
