Samsung S22 Ultra not fast charging
Twinsunian
Valued Contributor
Valued Contributor
Hello All,
My Samsung S22 Ultra is less than 1 year old. For some reason it is no longer fast charging. I have tried various compatible cables and plugs to no avail. I have checked the charging settings and battery settings/status where everything seems to be normal.
Leanne_T
Hi @Twinsunian
Welcome back to the community.
Have you tried the steps in the My Galaxy device is not fast charging how do I fix it?, Samsung support page?
Thanks 🙂
Twinsunian
Valued Contributor
Valued Contributor
Hello! Everything has been followed and check... still no luck. Even with different cables.
Leanne_T
Thanks @Twinsunian
In this case, please get in touch with our tech gurus on 150 and the team will run through some troubleshooting and let you know the next steps to get this sorted 🙂
Northerner
Hi @Twinsunian
What plug are you using as they don't tend to last long. Same as the cable as they wear out.
Also it won't show as fast charging immediately you plug it in. Give it a minute or two and then tap on the screen.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
Hello!
I have been using 3rd Plug with official Samsung Cables, my Mrs' official Samsung plug and cable and also a Fast charging power bank with official Samsung Cables.
